Старый 17.09.2010, 20:05   #1
fatihdemirci: Axapta’dan direk SQL Insert, Update ve Delete işlemleri
Источник: http://www.fatihdemirci.net/index.ph...e-kayit-atmak/
Global  değişkenlerclass ETGHRMKariyerSync{    CCADOConnection         ADOConnection;    CCADOConnection         Connection; } UPDATEpublic static server void HRMEducationTypeUpdate(HRMEducationType _HRMEducationType ){    Statement   statement;    str         SQLCommand;    ;     // Set the SQL statement    SQLCommand = ‘SET DATEFORMAT DMY ‘;    SQLCommand += “UPDATE [Kariyer].[dbo].[WHRMEDUCATIONTYPE]“;    SQLCommand += strfmt(“SET [HRMEDUCATIONTYPEID] = ‘%1′ , [DESCRIPTION] = ‘%2′ , [DATAAREAID] = ‘%3′ , [RECVERSION] = %4 WHERE [RECID] = %5″
fatihdemirci: ExistsJoin ve NotExistJoin ile Lookup yazmak Blog bot DAX Blogs 0 11.02.2011 17:11
fatihdemirci: Ax ile belli bir klasordeki dosya ve klasorleri bulan metod Blog bot DAX Blogs 0 04.12.2010 14:11
C# and AX Development: How to delete AOT objects (AX/Axapta) Blog bot DAX Blogs 0 13.12.2007 19:50
Часовой пояс GMT +3, время: 11:09.
