Старый 18.10.2010, 10:05   #1
East Ocean - Technical: No organization was specified in the configuration file
Источник: http://eastoceantechnical.blogspot.c...cified-in.html
Recently, one of the client reported that the outlook client configuration wizard prompt them this error message during the CRM 4 outlook client setup.
It seems like too general for system admin to figure out the issue behind.
Besically it is caused by the particular user was not add to CRM system, thats why setup wizard can't populate the related organization and its data.
Just add the user to CRM system and grant him related privilege, case close :)
I was thinking of showing access denied is more easy for us to find out the root cause, what do you think...?
East Ocean - Technical: Always focus on solutions, not on problems. Blog bot Dynamics CRM: Blogs 1 13.10.2010 16:25
East Ocean - Technical: Configuration registry key is invalid Blog bot Dynamics CRM: Blogs 0 22.09.2010 23:05
East Ocean - Technical: CRM 4 - Small changes:big effect Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
East Ocean - Technical: Maximum attributes supported by CRM 4! Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 01:56.
