Старый 12.11.2010, 01:11   #1
sumitax: Resolving ‘No Business Connector session not found’ error EP
Источник: http://sumitax.wordpress.com/2010/11...ound-error-ep/
Following are ways to troubleshoot this business connector issue.
1. If you are doing remote development(i.e. on a server e.g. Win 2003) with VS2008 and AX , then make sure you have valid AX client session with same user you login in VS2008.
2. Check under Administration–> Online users that you have session for “Business connector” user.
3. If you are debugging in AX through VS2008 make sure AX Debugger client session open before running breakpoint.
ax2009, business connector, enterprise portal
workflowax: No .NET Business connector session found. Blog bot DAX Blogs 0 02.11.2010 20:05
Dynamics Ax: Workflow Error “No .NET Business Connector Session could be found” in Dynamics AX2009 Blog bot DAX Blogs 0 18.09.2010 21:06
sumitax: Trobleshooting Project/AxBaseUserControl.ascx does not exist error Blog bot DAX Blogs 0 19.08.2010 10:05
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 03:51.
