Старый 03.12.2010, 15:11   #1
25,644 / 848 (80) +++++++
dynamicsaxbi: AX SSRS Reporting ScreenCast List
Источник: http://blogs.msdn.com/b/dynamicsaxbi...cast-list.aspx
To help you find the right screencast, below is a list of all of them that have been produced so far and some that are scheduled to be created. This list will be updated as additional screencasts become available.
ScreenCast 1: Create the Simplest Possible Report with Visual Studio
URL: http://www.youtube.com/watch?v=oJCj9mCo-9I
  • Creating a New Report Library
  • Creating a new Report Model
  • Creating a dataset an dbinding it to an AX Query
  • Previewing the Report in Visual Studio
ScreenCast 2: The Case of the Mysterious Parameter
URL: http://www.youtube.com/watch?v=kdfpMBF-kMA
  • parameters created automatically from query ranges
ScreenCast 3: Better Looking Reports with Templates
URL: http://www.youtube.com/watch?v=wzi4czp3cjQ
  • templates for Auto Designs
  • style template
  • layout templates
  • adding the shared library to the solution
  • referencing the shared library in a report library
ScreenCast 4: AX SSRS Reporting Concepts
URL: http://www.youtube.com/watch?v=8dQomypSAgQ
  • Report Libraries
  • Report Models
  • Report Designs
  • DataSets
  • Designs
  • AutoDesign & Precision Designs
  • Designs versus RDL
ScreenCast 5: Launching a Report from a Menu Item
URL: http://www.youtube.com/watch?v=bHF24bZJA_A
  • Saving a report library to AOD
  • Deploying a report library to SSRS
  • Rnning a Report in SSRS Report Manager
  • Creating an Output Menu Item and binding it to a report design
ScreenCast 6: Default Values for Parameters and Hiding Parameters
URL: http://www.youtube.com/watch?v=SZRqYx32HwY
  • Providing Defaults for Parameters And Hiding Parameters
  • Default Parameter Values
  • Hiding Parameters
ScreenCast 7: Debugging Parameter Values in AutoDesigns
URL: Not yet published
  • The "Render Parameters" property on Auto Designs designs
ScreenCast 8: Manually Creating Designs and DataRegions
ScreenCast 9: Multiple Data Regions in AutoDesigns
Future Topics
  • Sizing Columns in AutoDesigns
  • Providing choices for parameters
  • End-User filtering of data on the SSRS Server
  • Alternating Row Colors
  • Customizing Templates
  • Charting
  • Images / Static
  • Images / From AX
  • Images / Dynamic
  • Getting Labels from AX
  • Creating a Customized Parameter Experience
  • Programmatically executing a Report
  • PowerPivot and AX2009
  • simple DataMethods
  • DataMethods to generate Data
  • Common Libraries of DataMethods
emeadaxsupport: How to install AX 4.0 Reporting Role with SSRS 2008 Blog bot DAX Blogs 2 23.01.2010 08:02
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Часовой пояс GMT +3, время: 04:45.
