Старый 11.03.2011, 14:11   #1
25,644 / 848 (80) +++++++
gustafwesterlund: CRM 2011 Online and datawarehousing
Источник: http://gustafwesterlund.blogspot.com...rehousing.html
I attended a half day presentation by Microsoft yesterday on the subject of Dynamics CRM 2011 and integrations. It seems that many parterners are a bit hesistant to integrating Dynamics CRM 2011 Online and are promoting the on-premise versions when the issues of integration are important.
Microsoft did a good job in showing that they do have sufficient technology to handle integrations to Dynamics CRM 2011 Online including the Azure based technology ACS - Access Control System that together with Active Directory Federation Services 2.0 can be used to allow Dynamics CRM 2011 Online to use a local AD as authenticator. It is probably not as easy as setting up a normal on-premise solution but at least it can be done and there hopefully are some whitepapers or Youtube-clips on how it is done.
One of the issues that were discussed was the issue of integrations in reagards to Business Intelligence and data warehousing. This is usually done using SQL Integration Service (SSIS) with direct SQL communication. Their suggestion on how to address this issue was to use the new OData interface that exists in Dynamics CRM 2011. I am no SQL expert but I do believe that this being a standardized protocol, integrations will be possible. However, there will still be issues with performance as the amounts of data that need to be transfered are quite large and the OData protocol is still a strict pull-protocol which does not allow for trigger-based updates.
Another issue that I asked about was the licensing issue in regards to Dynamics CRM 2011 Online. Take the following example: A large company of about 40 000 employees has about 500 people activly working in with Dynamics CRM 2011 Online for SalesForceAutomation. A data warehouse is created and data is integrated from many different systems, ERP, production systems, quality control systems and CRM. CRM being the customer data master. SharePoint is used as the global Intranet platform and some of the data from the data warehouse is published on the SharePoint portal to all employees. For instance our currently 10 most important customers. So, the 39 500 employees are only viewing a minute part of the customer data, and it indirecty, via the data warehouse, originates from the CRM system. What licenses in CRM are required for these users?
In the case of an on-premise installation, the best licensing option for Dynamics CRM is the Application Platform Agreement (APA) that is sort of a "free-for-all pass" which is negotiated with Microsoft. However, in the Online environment there is no correlating licensing agreement to the APA. I explicitly asked Micrsoft how this was to be licensed and their answer is that 40 000 separate users licenses are required for Dynamics CRM 2011 Online, making it a rather impossible option, in other words forcing the company to either an on-premise solution, removing some of the data from the data warehouse/Intranet or moving to another CRM supplier. Neither of which is in line with showing off the power of Microsofts cloud services.
I hope this is just a temporary flaw since it does limit Microsofts business opportunities with larger companies and I would think it is probable that some similar agreement form that matches the on-premise APA will be introduced.
On the other hand, the External Connector license is not required at all for CRM Online (or SPLA) making it even more interesting for smaller CRM customers as customer/event/portal integrations are more and more common.
Gustaf Westerlund
CEO, Chief Architect and co-Founder at CRM-konsulterna AB
www.crmkonsulterna.se
Часовой пояс GMT +3, время: 14:12.
