Старый 07.04.2011, 12:11   #1
msdax: How to get SID to be used with AX Administration?
Источник: http://msdax.blogspot.com/2011/04/ho...d-with-ax.html
Question:
I have reinstalled my windows but want to use the same AX. The issue is my AX needs to be configured based on new SID. How to get the new SID?
Answer:
There is a very simple program that can be used to retrieve your new SID and then you can use it for configuration.
http://technet.microsoft.com/en-us/s.../bb897417.aspx
msdax: How to Specify Range Values on a Query in a AX SSRS Report - AX Support - Site Home - MSDN Blogs Blog bot DAX Blogs 0 31.03.2011 11:11
dax-lessons: Get SID [Security ID] of windows user using X++ [Dynamics AX] Blog bot DAX Blogs 0 11.03.2011 20:11
Часовой пояс GMT +3, время: 08:01.
