Старый 10.04.2011, 08:19   #1
dax-lessons: Easy drag and drop – files [Document Management] with minimum X++ Coding [Dynamics AX]
Источник: http://dynamicsaxgyan.wordpress.com/...g-dynamics-ax/
Friends, Normally we attach a document using the Document handling icon on the tool bar and select appropriate options in attaching a file. Well, I was going through smmDocuments form and found a drag drop ActiveX control which can make … Continue reading →
Palle Agermark: Drag and Drop files to Dynamics AX Blog bot DAX Blogs 2 18.06.2024 12:55
paruvella: Dynamics Ax Document Handling For The Mails Using Drag n Drop Blog bot DAX Blogs 0 20.11.2009 20:05
paruvella: Dynamics Ax Document Handling using File Drag n Drop Blog bot DAX Blogs 0 12.11.2009 21:05
dynamic-ax.co.uk: Import Emails from Outlook 2007 into Dynamics AX 2009 Blog bot DAX Blogs 1 03.07.2009 07:17
jerry-dynamics: Where can you drag and drop an extended data type to? Blog bot DAX Blogs 0 16.06.2007 11:20
Часовой пояс GMT +3, время: 20:38.
