Старый 17.05.2011, 01:14   #1
Dynamics AX Sustained Engineering: Financial Statement calculation column behavior with Currency Converter
Источник: http://blogs.technet.com/b/dynamicsa...converter.aspx
Problem:
When using the currency converter on a Financial Statement, calculation columns are restated. In some cases, this may not be desirable as the calculation column may already contain information as needed. An example would be a calculation column consisting of a sum of two columns that contain secondary currency information.
Resolution:
To resolve this issue the class \Classes\LedgerBalanceSheetDimPrint\buildFields can be modified as follows. The changes consist of moving one of the case statements to an earlier point in the code.
case LedgerColumnTypeDim::CurrentCur,
LedgerColumnTypeDim::BudgetCur,
LedgerColumnTypeDim::CovCur :
reportRealField.extendedDataType(extendedtypenum(AmountCur));
reportRealField.dataMethod(#methodDisplayAmountCur);
break;
To:
LedgerColumnTypeDim::CovCur,
LedgerColumnTypeDim::CalcExpression :
break;
and remove\comment the code in the following case statement.
case LedgerColumnTypeDim::CalcExpression :
reportRealField.extendedDataType(extendedtypenum(AmountMST));
reportRealField.dataMethod(#methodDisplayAmountMst);
break;
Dynamics AX Sustained Engineering: POS Transaction with Sales Order that nets to $0.00 posting failure in statement Blog bot DAX Blogs 0 06.01.2011 20:16
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 11:10.
