#1 |
axinthefield: XBRL Taxonomy (Import & Export of reports)
Источник: http://blogs.msdn.com/b/axinthefield...f-reports.aspx
============== XBRL : eXtensible Business Reporting Language (XBRL) (Global Financial Reporting initiative) Reporting: Financial statements, information, non-financials information and regulatory filings. Use the XBRL feature in Microsoft Dynamics AX 2009 to:
Path: General Ledger > Setup > Posting > XBRL Taxonomy ![]() Export File: Path: General Ledger > Reports > Transactions > Periodic > Select out put type = XBRL ![]() This enables tab 'XBRL' ![]() XBRL specific versions available are 2.0 & 2.1. (Select the version required, latest version is 2.1 and find the following URL to understand XBRL specifications) URL: http://xbrl.org/SpecRecommendations Specify the file name & location to store This creates an xml type file for the data. Источник: http://blogs.msdn.com/b/axinthefield...f-reports.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
