Старый 05.07.2011, 22:11   #1
dax-lessons: Deactivating configuration key will not affect the table any more [Dynamica AX 2012]
Источник: http://dynamicsaxgyan.wordpress.com/...amica-ax-2012/
Friends, In DAX 2009 or earlier versions, deactivating a configuration key affected a table in Microsoft Dynamics AX and the associated table was removed from the underlying Microsoft SQL Server database. In Microsoft Dynamics AX 2012, the associated tables are … Continue reading →
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 01:20.
