Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 18.07.2011, 01:48   #1
ideveloper is offline
ideveloper
How to overwrite a display value of the edit field
Hi all.
I have the following problem:
I have 2 data tables which represent the relation between the customers and the bonus codes.
Table A
BonusCode | recId
Table B
AccountNum | ArticleNum | TableARecId (as key)
Now I am trying to create a form containing the grid with the AccountNum, ArticleNum and the BonusCode. The BonusCode field should have a lookup function to the data in the Table A. When I get the value of the BonusCode with the display method I must create my own lookup method from zero to have the possibility to choose the data.
Could I instead include the TableARecId in the grid as the edit field and overwrite the show method to show the value of the bonus code???
Старый 26.07.2011, 07:54   #2
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
Аватар для TasmanianDevil
887 / 389 (14) ++++++
Сообщение от ideveloper Посмотреть сообщение
For what ?
You may use edit-method on TableB datasource for displaying and editing BonusCode on the grid.
edit <BonusCodeType> BonusCodeValue(boolean set, TableB record, str Id)
    if(set)
        record.TableARecId = str2int64(id);
    return (select BonusCode from TableA where TableA.RecId == record.TableARecId).BonusCode;
Override lookup() method on the control (usig SysTableLookup class or control method performTypeLookup() ), placed on the grid and assigned to edit method - he will be used as source of Id value in edit method. One value - one control. Something else is unnatural
edit field, lookup, overwrite display value
dynamicsaxtraining: How to access field in a table using this field id Blog bot DAX Blogs 0 09.12.2010 02:13
dynamicsaxtraining: How dynamically change data source field properties Blog bot DAX Blogs 0 06.12.2010 23:11
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
Зачем нужны display и edit методы Андре DAX: Программирование 4 15.08.2002 13:24
edit и display методы Maxim Gorbunov DAX: База знаний и проекты 4 15.01.2002 12:58
Часовой пояс GMT +3, время: 18:03.
