Старый 03.08.2011, 09:11   #1
crminthefield: CRM 2011: Silently Installing Update Rollups
Источник: http://blogs.msdn.com/b/crminthefiel...e-rollups.aspx
Many of my customers like to install CRM Outlook client update rollups silently in order to limit end-user interruption. It is possible to silently install Update Rollups. I've listed the necessary steps below:
  • Download the CRM update rollup that you'd like to apply from the Microsoft Download Center (ex. CRM2011-Client-KB2547347-ENU-i386.exe)
  • Extract the update rollup package (CRM2011-Client-KB2547347-ENU-i386.exe /extract)
  • After extracting the package, you'll see a file named CrmUpdateWrapper.exe
  • To silently install the update rollup via a command prompt, launch the CrmUpdateWrapper (ex. crmupdatewrapper.exe /q /log "C:\log\log.txt")
    • The above syntax silently installs the update rollup and creates a log file in the specified folder. Additional parameters that can be used are:
      • /? = available parameter options
      • /q = silent install
      • /passive = installer/uninstall runs in passive mode
      • /norestart = even if required, does not restart the computer after installation is completed
      • /forcerestart = even if it is not required, restarts the computer after installation is completed
      • /promptrestart = prompts the user to restart the computer after the installation is completed when a restart is required
      • /uninstall = update is uninstalled
      • /log = user can define the log file local path name
While it is definitely possible to run the above silent install from a command prompt, most customers will choose to use these parameters when pushing out update rollups through deployment software (ex. System Center Configuration Manager).
- Jon
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 18 Blog bot Dynamics CRM: Blogs 0 01.07.2011 02:12
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 06.05.2011 09:11
Все о Microsoft Dynamics CRM: Как установить Microsoft Dynamics CRM 2011 Beta Blog bot Dynamics CRM: Blogs 0 31.10.2010 15:08
Часовой пояс GMT +3, время: 14:17.
