Старый 10.08.2011, 02:17   #1
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 SP2 and AX 2009 SP1 are compatible with Microsoft Windows 7 SP1 and Microsoft Windows Server 2008 R2 SP1
Источник: http://blogs.technet.com/b/dynamicsa...08-r2-sp1.aspx
Dynamics AX Sustained Engineering is proud to announce the following compatibility between the released versions of Dynamics AX and Windows 7 Sp1 and Windows Server 2008 R2 SP1 :
Microsoft Product
Dynamics AX Version
Dynamics AX 4.0 SP2 and Dynamics AX 2009 SP1, Operating System Supported in 64 bits only.
Windows 7 Sp1
Dynamics AX 4.0 SP2 and Dynamics AX 2009 SP1, Supported as a client only, in 32 bits and 64 bits
The System requirements of Dynamics AX 4.0 and AX 2009 will be updated on Customer Source and Partner Source.
Follow the Dynamics AX Sustained Engineering blog for the latest updates on the above. For further information, feel free to contact daxsecom@microsoft.com
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 SP2 with Dynamics AX Blog bot DAX Blogs 0 18.05.2011 05:16
Rahul Sharma: Install Microsoft Dynamics AX 2009 SP1 on Windows 7 Blog bot DAX Blogs 0 04.05.2011 21:13
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Часовой пояс GMT +3, время: 01:25.
