Старый 27.08.2011, 20:11   #1
Kurt Hatlevik: Consolidated production picking using WM&D
Источник: http://kurthatlevik.wordpress.com/20...ing-using-wmd/
In standard AX the production module do have a separate process of generating picking routes, but it is possible to set up std. AX so that consolidated picking routes are generated. The advantage is that then the picking routes generated … Continue reading →
Kurt Hatlevik: WM&D Value Added services Blog bot DAX Blogs 0 22.08.2011 23:11
Kurt Hatlevik: WM&D – Assembly and kitting Blog bot DAX Blogs 0 21.08.2011 22:13
Kurt Hatlevik: Transportation planning in WM&D Blog bot DAX Blogs 0 14.06.2011 01:11
Kurt Hatlevik: PICKING / PACKING in WM&D Blog bot DAX Blogs 0 13.05.2011 03:54
Kurt Hatlevik: GOODS RECEIPT in WM&D Blog bot DAX Blogs 0 13.05.2011 03:54
Часовой пояс GMT +3, время: 06:29.
