Старый 01.09.2011, 01:11   #1
25,644 / 848 (80) +++++++
sumitax: AX2009 – Unable to create Client Sessions
Источник: http://sumitax.wordpress.com/2011/08...ient-sessions/
In my current Project , I was unable to login into AX and getting the message  “Unable to start user session . The transaction log for Database XXX is full.Please clear the log and try again.Following is the fix for this error :
  1. Go to Server Configurations file to identify the Database being used .
  2. Login to SQL Mangament Studio  Right Click and Go to Properties of respective Database.
  3. Go to General Tab and get the increase the size of  Transaction Log i.e. the ldf File to allowable size (in MB  depending on hard disk size available on respective Drive on Database server which holds the .Ldf file).
  4. Now login to AX . You should be get a client session successfully.
sumitax: Upgrade scripts AX 4.0 to AX2009 Upgrade -Post synch step Blog bot DAX Blogs 0 03.08.2011 09:11
sumitax: AX4.0 to AX2009 Upgrade Back to Basics Blog bot DAX Blogs 0 29.06.2011 19:12
sumitax: Creating new GUID in AX2009 Blog bot DAX Blogs 0 17.11.2010 18:11
sumitax: SharePoint 2010 and AX2009 Blog bot DAX Blogs 0 11.11.2010 11:11
sumitax: Workflow Installation Steps -AX2009 Blog bot DAX Blogs 0 14.10.2010 23:06
Часовой пояс GMT +3, время: 18:26.
