Старый 30.09.2011, 01:19   #1
emeadaxsupport: Microsoft BizTalK Server 2010 passes compatibility testing with Microsoft Dynamics AX 2009 SP1
Источник: http://blogs.msdn.com/b/emeadaxsuppo...-2009-sp1.aspx
Earlier this week I was informed that Microsoft BizTalK Server 2010 has passed compatibility testing with Microsoft Dynamics AX 2009 SP1. See http://blogs.technet.com/b/dynamicsa...rver-2010.aspx for more details.
I would recommend that if you are using BizTalk Server integration to at least have Microsoft Dynamics AX 2009 SP1 Hotfix Rollup 7 Kernel installed as aminimum on all your AX systems. This Kernel build contains the following AX BizTalk adapter fixes and enahnacements:
2389818: "Requested Service not found" error message when you use the BizTalk connector adapter in Microsoft Dynamics AX 2009 Service Pack 1
The BizTalk adapter cannot handle response messages from Microsoft Dynamics AX 2009 SP1 on a successful delete service action or a successful update service action
and other kernel updates from previous rollups.
--author: Anup Shah --editor: Anup Shah --date: 29/Sept/2011
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 19 Blog bot Dynamics CRM: Blogs 0 26.08.2011 01:13
Часовой пояс GMT +3, время: 15:44.
