Старый 27.10.2011, 04:14   #1
Microsoft Dynamics CRM Team Blog: CRM 2011 Charts – Charting on Related Records
Источник: http://blogs.msdn.com/b/crm/archive/...-records1.aspx
This blog demonstrates how to create a chart from data in the current entity alongside data from related entities.
Let’s take the following scenario:
A Not For Profit Organization is using CRM 2011 to track the pledges and donations made by their donors.
Each pledge a donor makes has a Pledge Amount and will have 1 to * donations associated to it. Each Donation has a Cash-Value and a Status. The Status will have one of the following values: Outstanding, Processing, or Collected.
The CRM user that is responsible to manage the pledges for a given cause needs to be able to quickly see the status of a given pledge i.e. the original amount of the pledge and the amount collected. One possibility is to show the following chart in the Pledge form:
where:
  • Pledged is the Pledge Amount. This value is only available in the Pledge entity (e.g. $1000).
  • Collected is the sum of all the Cash-Value of the Donations that have been collected. (e.g. three donations @ $200 have been collected)
We will cover how to:
  • Display the value of a field (Pledge Amount) from the current entity (Pledge) in the chart. This is not possible out of the box because a chart can only display field values from a related entity (Donation).
  • Display the sum of the values (Cash-Value) of related entities (Donation) having a specific Status (collected).
To create this chart and display it in the Pledge form, do the following:
1. Go to Settings > Customizations > Customize the System.
2. Create a Pledge entity with the field ‘Pledge Amount’ and a Donation entity with the fields ‘Cash-Value’ and ‘Status’.
3. Open the Donation entity
4. Create a new bar chart
5. Create a series for the field Cash Value.
6. Open the Pledge main form
7. Add a One Column Section
8. Insert a Sub-Grid. Enter the unique Name and Label. Select the entity (Donations) and the default View. Also check the box ‘Show Chart Only’ in order to hide the sub-grid.
9. In the formatting tab, set the number of rows to 12
10. Save, Close, and Publish all the customizations
11. Open a Pledge form
12. You will see the following chart.
13. Add a Global OptionSet in order to be able to change the legends’ labels
  • Go to Settings > Customizations > Customize the System.
  • Click on ‘Option Sets’ in the left pane and click on the menu item ‘New’
  • Add the 2 Options: Pledged and Collected.
14. Now we have to manually modify the chart.
15. Export the chart.
  • On the left pane, select Components > Entities > Donations > Charts
  • Select the chart ‘Pledge Status By Amount’
  • Click on the ‘More Actions’ > Export Chart and save the chart on your hard drive
16. Open in your favorite XML editor or notepad
17. Replace the generated with the following:
  • The first Customize the System.</span></span>
  • On the left pane, select Components > Entities > Donations > Charts.
  • Click on the &lsquo;More Actions&rsquo; > Import Chart and browse to the modified chart on your hard drive. Click OK.
  • Import will find that the chart is a duplicate. When asked, select &lsquo;Replace&rsquo;.
23. Publish all the customizations.
24. Open a Pledge entity.
Final result
Summary:
We have showed you how to manually modify CRM 2011 charts in order to:
  • Display the value of a field from the current form
  • Display the filtered value of the field from a related entity
  • Rename the legends&rsquo; labels
For more information on how to further modify the CRM 2011 charts, see also the blogs
&ldquo;CRM 2011 Charts &ndash; Know the Real Potential&rdquo;, Part 1 and Part 2.
Christian J. Betrisey
Here is the full chart XML that we modified in this example:
{AB00D3AF-49E9-E011-B89B-00155DA96A01}
Pledge Status by Amount
new_donation
false
Microsoft Dynamics CRM Team Blog: Announcing: Microsoft Dynamics CRM 2011 Implementation Guide update 5.2.0 Blog bot Dynamics CRM: Blogs 0 15.08.2011 23:11
Microsoft Dynamics CRM Team Blog: What’s New in Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 12.04.2011 08:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 Release Candidate (RC) Announcement Blog bot Dynamics CRM: Blogs 0 15.12.2010 11:11
Все о Microsoft Dynamics CRM: Как установить Microsoft Dynamics CRM 2011 Beta Blog bot Dynamics CRM: Blogs 0 31.10.2010 15:08
Часовой пояс GMT +3, время: 14:15.
