Старый 16.12.2011, 11:11   #1
sumitsaxfactor: Dimension Provider Class and Run-time dimension ranges [AX 2012]
Источник: http://sumitsaxfactor.wordpress.com/...anges-ax-2012/
While working on a requirement for ledger amounts, I had to find out a way to filter the transactions for a specific dimension value of a specific dimension type; from ledger transactions of a main account.
Now had it been Ax 2009, it was pretty simple where you could provide a range on Dimensions[arrayIndex] field. But in Ax 2012 the dimensions on a transaction are always stored a combination value rather than a separate value.
While running the query, I found a support provided by MS where-in all the dimensions will be added as fields for a table having Ledger dimensions on run-time. Now if we were running a query manually, we will be able to specify the range manually as shown below:
For demo purpose, I am using GeneralJournalAccountEntry table that holds the amounts for transactions posted to a main account
Now try and add a range, when you select the drop-down on the Field column, you will notice new fields added to the drop-down
The concept behind is that, these fields are added at run-time and when you add a range to any of these fields, a view (DimensionAttributeLevelValueView) will be dynamically added for each field range record you create, as a child DS for GeneralJournalAccountEntry
This is what the SQL statement looks like at the backend
SELECT*FROM GeneralJournalAccountEntry(GeneralJournalAccountEntry_1)JOIN*FROM DimensionAttributeLevelValueView(DimAttCol_GeneralJournalAccountEntry_1_LedgerDimension_5637145354)ON GeneralJournalAccountEntry.LedgerDimension = DimensionAttributeLevelValueView.ValueCombinationRecId AND((DimensionAttribute = 5637145354))AND((DisplayValue =N’000001′))
Now when we are running queries manually, we can specify such kind of a range, what if we have to do the same thing while running a query at a backend or through a code?
Here comes the DimensionProvider class to our rescue. This class will help us add such ranges as required. Look at the sample job below for some guidance.
staticvoid addDimensionRange(Args _args)
    Query                   query = new Query();
    QueryRun                queryRun;
    QueryBuildDataSource    qbds;
    DimensionProvider       dimensionProvider = new DimensionProvider();
    GeneralJournalAccountEntry  accEntry;
    DimensionAttribute      dimAttr;
    Name    dimAttrNameEmpl, dimAttrNameCostCenter;
    int i;
    selectfirstOnly dimAttr where dimAttr.BackingEntityType == tableNum(DimAttributeHcmWorker);
    dimAttrNameEmpl = dimAttr.Name;
    selectfirstOnly dimAttr where dimAttr.BackingEntityType == tableNum(DimAttributeOMCostCenter);
    dimAttrNameCostCenter = dimAttr.Name;
    qbds = query.addDataSource(tableNum(GeneralJournalAccountEntry));
    dimensionProvider.addAttributeRangeToQuery(query, qbds.name(), fieldStr(GeneralJournalAccountEntry, LedgerDimension), DimensionComponent::DimensionAttribute, SysQuery::valueNotEmptyString(), dimAttrNameEmpl, true);
    dimensionProvider.addAttributeRangeToQuery(query, qbds.name(), fieldStr(GeneralJournalAccountEntry, LedgerDimension), DimensionComponent::DimensionAttribute, SysQuery::valueNotEmptyString(), dimAttrNameCostCenter, true);
    queryRun = new QueryRun(query);
    queryRun.prompt();
    while(queryRun.next())
        accEntry = queryRun.get(tableNum(GeneralJournalAccountEntry));
        info(strFmt("%1 %2", DimensionAttributeValueCombination::find(accEntry.LedgerDimension).DisplayValue, accEntry.AccountingCurrencyAmount));
}Here is the sample output log
This is how the query will be if you prompt the query
Старый 28.08.2013, 12:42   #2
SRF is offline
SRF
376 / 562 (19) +++++++
Похоже в методе addAttributeRangeToQuery класса DimensionProvider в строке 58 используют не правильный тип соединения
public QueryBuildRange addAttributeRangeToQuery(Query _query, str _dataSourceName, str _dimensionFieldName, DimensionComponent _dimensionComponent, anytype _value, str _dimensionAttributeName='', boolean _isDefaultRange = false)
           // Change the join to an inner join since it is now restricting
            qbds.joinMode(JoinMode::InnerJoin);
При таком соединении из выборки уходят все строки, у которых не определено значение фин. аналитики, по которой накладываем условие.
Т.е. когда мы используем конструкцию вида
    SysQuery::addDimensionAttributeRange(
                query,
                qbds.name(),
                fieldStr(Example, DefaultDimension),
                SysQuery::valueUnlimited(),
                dimensionName,
                true);
будут отобраны все записи из таблицы Example, у которых аналитика dimensionName не пустая, даже не смотря на то, что значение мы передаем любое.
И еще один момент, в соседнем методе addAttributeFilterToQuery(он почти повторяет данный метод за исключением методов к которым применяются значения условий) этого же класса, используется уже OuterJoin.
public QueryFilter addAttributeFilterToQuery(Query _query, str _dataSourceName, str _dimensionFieldName, DimensionComponent _dimensionComponent, anytype _value, str _dimensionAttributeName = '')
           // Change the join to an outer join since it is now restricting with a filter
            qbds.joinMode(JoinMode::OuterJoin);
Sergey Nefedov
ax2012, dimensions
X++: X++ Compiler Changes in Dynamics AX 2012 Blog bot DAX Blogs 0 15.11.2011 01:13
X++: How to use X++ Delegates in Dynamics AX 2012 Blog bot DAX Blogs 0 03.08.2011 09:11
saveenr: Dynamics AX 2012: An Introduction to Report Data Providers Blog bot DAX Blogs 0 07.03.2011 12:11
Часовой пояс GMT +3, время: 21:46.
