Старый 14.02.2012, 12:11   #1
Microsoft Dynamics CRM Team Blog: Update Rollup 21 for Microsoft Dynamics CRM 4.0
Источник: http://blogs.msdn.com/b/crm/archive/...s-crm-4-0.aspx
The Microsoft Dynamics CRM Sustained Engineering (SE) team released Microsoft Dynamics CRM 4.0 Update Rollup 21 on Thursday, February 9, 2012.
The links below will take you to the necessary information about Update Rollup 21.
General details about Update Rollup 21
  • Update Rollup 21 is cumulative. However, the Update Rollup 21 CRM Client and Data Migration Client packages require Update Rollup 7 to be installed. For all other CRM components, you do not need to install any previous Update Rollups prior to Update Rollup 21.
  • The Update Rollup 21 download contains updates for the 40 supported Language Packs. Prior to installing the Update Rollup 21 Language Pack, you must install the original Language Pack.
    • If you have Language Packs installed, you should
      1. Download the Update Rollup 21 Language Pack
      2. Install the Update Rollup 21 Language Pack
      3. De-provision the Language Pack
      4. Re-provision the Language Pack
  • Information about how to avoid reboots when installing the CRM Outlook Client can be found in the Update Rollup 4 blog posting.
  • The Update Rollup 21 Client can be deployed before the server is upgraded to Update Rollup 21.
  • Steps to make the Update Rollup 21 Client available via AutoUpdate can be found in the Update Rollup 4 blog posting. The Link and Patch IDs can be found in KB article 2550098.
  • Each update rollup could have fixes that require manual configuration. Please see the “Hotfixes and updates that you have to enable or configure manually” section in KB article 2621054.
Future Updates for CRM 4.0
Due to the low volume of fix requests for CRM 4.0, the CRM SE team will stop shipping CRM 4.0 rollups on a regular schedule. CRM SE will service CRM 4.0 requests on an individual basis using our Critical On-Demand process.
CRM SE will continue to evaluate the need for Update Rollups for the remainder of CRM 4.0’s supported lifecycle. A rollup will be shipped if there is a significant increase in fix request volume or in the event that a rollup will benefit a majority of the 4.0 installation base.
How to get support for Update Rollup 21
For support, please contact Microsoft Product Support. For a complete list of Microsoft Product Support Services telephone numbers and information about support costs, visit the following Microsoft Web site: http://support.microsoft.com/default.aspx?scid=fh;[LN];CNTACTMS.
Note: In special cases, charges ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The usual support costs
will apply to additional support questions and issues that do not qualify for the specific update in question.
Cheers,
Matt Brown
Старый 14.02.2012, 20:55   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Все, отжила, старушка...
Старый 14.02.2012, 20:56   #3
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Перефразирую известное выражение - продукт жив, пока ещё жив хоть один деплоймент.
Старый 20.01.2022, 01:21   #4
Tony Green is offline
Tony Green
Аватар для Tony Green
184 / 25 (1) +++
Коллеги, я понимаю, что хочу странного в 2022 году, но может у кого-то завалялся этот самый Microsoft CRM 4.0 Update Rollup 21?
На худой конец можно только CRMv4.0- KB2621054-amd64-Server-RUS.exe из него.
Очень бы выручили
Tony Green
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 21 Blog bot Dynamics CRM: Blogs 0 11.02.2012 01:11
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 06.05.2011 09:11
Microsoft Dynamics CRM Team Blog: Update Rollup 14 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 19.11.2010 03:45
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 14.03.2009 07:10
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 - More Info Blog bot Dynamics CRM: Blogs 0 12.02.2009 13:05
Часовой пояс GMT +3, время: 23:18.
