Старый 25.02.2012, 05:42   #1
25,644 / 848 (80) +++++++
axperf: Batch Parallelism in AX – Part - II
Источник: http://blogs.msdn.com/b/axperf/archi...x-part-ii.aspx
  Individual Task Modeling Here in this case parallelism is achieved by creating a separate task for each work unit. You model the tasks by creating a task for each work item. You will have 1:1 mapping between task and the work item. This will eliminate...(read more)
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 16:53.
