Старый 12.07.2012, 00:14   #1
25,644 / 848 (80) +++++++
kamalblogs: Dynamics ax 2012 – Copying Temp Table instance for SQL TempDB
Источник: http://kamalblogs.wordpress.com/2012...or-sql-tempdb/
SQL Temp db introduced in Dynamics Ax 2012 is powerful then the “In memory” tables that was in use so far. It works across tiers and is relatively easier to understand and use.
This  post is about creating a new instance link(Populating data/Copying Reference) from one table instance variable to the other with SQL temp db type tables. With the standard “In memory” tables to copy the reference we use the “setTmpData” but for SQL temp db use the method mentioned below
static void UsingInMemory(Args _args){ //Inmemory TmpABC abc, newAbc; abc.Amount = 50; abc.insert(); newAbc.setTmpData(abc);}static void UsingSQLTempDB(Args _args){ //SQL TempDB TmpABC abc, newAbc; abc.Amount = 50; abc.insert(); newAbc.linkPhysicalTableInstance(abc);}
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 03:19.
