Старый 15.08.2012, 09:11   #1
emeadaxsupport: AX2012 Retail: MS Sync Service fails to synchronize transactions from offline database
Источник: http://blogs.msdn.com/b/axsupport/ar...-database.aspx
Synchronization
issue between Offline database and Store database
Issue description
We recently had a case where an offline POS refused to sync transactions to the store database after
it came back online. This retail systemconsisted of a centralized store database and an offline database for each of
the POS machines. On each POS the Microsoft Sync service was running to synchronize the offline database with the
store database. The offline databases were created using the Retail Database Utility and had data, so offline sync had been working at one point.
Troubleshooting
To troubleshoot, we enabled tracing on the AX for Retail
Offline Sync Service as described in this article:
The outcome was following:
ERROR , Microsoft.Dynamics.Retail.Offline.Service, 21,
08/13/2012 14:59:20:313, The current operation could not be completed because
the database is not provisioned for sync or you not have permissions to the
sync configuration tables. Exception: Microsoft.Synchronization.Data.DbNotProvisionedException:
completed because the database is not provisioned for sync or you not have
permissions to the sync configuration tables.
at
Microsoft.Synchronization.Data.SqlServer.SqlManagementUtils.VerifyRuntimeVersionExceedsSchema(SqlConnection
connection, String objectPrefix, String objectSchema, Boolean
throwWhenNotProvisioned)
Solution
We discovered that the store database was missing three tables that manage the sync configuration: scope_info, scope_config, and schema_info.
These tables are normally created in the process of creating any new offline database using the Retail
Database Utility. In order to recreate these tables in just the store database we created a new offline database using
the utility (making sure to create a backup of the existing offline database). After this we ran the N-1095
job and restarted the AX for Retail Offline Sync Service which resolved the issue.
Related documentation
Microsoft Sync Framework documentation
http://msdn.microsoft.com/en-us/library/bb902854.aspx
How to: Provision and Deprovision
Synchronization Scopes and Templates
http://msdn.microsoft.com/en-us/library/ff928603.aspx
Release
Notes for Microsoft Sync Framework 2.1
http://download.microsoft.com/downlo...leaseNotes.htm
Authors: Shane Erstad & Kim Truelsen
Date: 15/8-2012
emeadaxsupport: AX 2012 Retail: Timeout in DBUtility while installing Offline database Blog bot DAX Blogs 0 09.08.2012 12:11
emeadaxsupport: AX 2012 Retail: Creating Offline Database fails Blog bot DAX Blogs 0 14.05.2012 17:11
emeadaxsupport: AX for Retail 2012: Customizing the Transaction Service Blog bot DAX Blogs 0 19.04.2012 01:14
emeadaxsupport: AX for Retail: Tip for Troubleshooting the Retail Transaction Service Blog bot DAX Blogs 0 25.01.2012 10:11
Часовой пояс GMT +3, время: 14:21.
