Старый 20.09.2012, 17:11   #1
axaptacorner: How to read CSV files in AX 2012 through X++ code
Источник: http://axaptacorner.blogspot.com/201...n-ax-2012.html
Through following code we can read CSV files
static void ReadCsvFile(Args _args)
#File
IO iO;
CustAccount custAccount;
CustName custname;
FilenameOpen filename = "d:\\jit.csv";//To assign file name
Container record;
boolean first = true;
iO = new CommaTextIo(filename,#IO_Read);
if (! iO || iO.status() != IO_Status::Ok)
throw error("@SYS19358");
while (iO.status() == IO_Status::Ok)
record = iO.read();// To read file
if (record)
if (first) //To skip header
first = false;
else
custAccount = conpeek(record, 1);//To peek record
custname = conpeek(record, 2);
info(strfmt('%1--%2',custAccount,custname));
Happy X++ coding!!!
axaptacorner: How to Import CSV files and how make Log files in Ax 2012 through X++ Blog bot DAX Blogs 0 20.09.2012 17:11
axaptacorner: How to create General Journal in AX 2012 by X++ code Blog bot DAX Blogs 0 10.09.2012 23:15
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
Часовой пояс GMT +3, время: 11:10.
