Старый 09.10.2012, 17:11   #1
ax-erp: Modifying CreatedDateTime
Источник: http://microsoft-dynamics-ax-erp.blo...ddatetime.html
For testing purposes with the MRP we needed to modify the createdDateTime fields in Dynamics Ax 2009. Since these are system fields we needed a workaround.
if(isRunningOnServer() && CurUserId() == "Admin")
new OverwriteSystemfieldsPermission().assert();
salesLine.overwriteSystemfields(true);
// "YYYY/MM/DD HH:MM:SS"
salesLine.(fieldnum(SalesTable,CreatedDateTime)) = str2datetime( "2010/04/03 11:00:00" ,321 );
salesLine.doInsert();
salesLine.overwriteSystemfields(false);
Remarks:
  • Make sure that it is running on the server tier
  • It only works on insert NOT on update
Since this code is pretty exotic and you don’t want to release this to a production environment we eventually didn’t use this but ran some sql jobs, but this shows that it is possible.
*edit*
Easy does it
DECLARE @DATAAREAID nvarchar(4)
DECLARE @SALESID nvarchar(20)
DECLARE @DATETIME datetime
/* EDIT THE FIELDS BELOW */
SET @DATAAREAID = 'CEU'
SET @SALESID = '00003352_058'
SET @DATETIME = '01/01/98 00:00:00.000'
/* DO NOT EDIT HERE */
UPDATE dbo.SALESTABLE
SET CREATEDDATETIME = @DATETIME
WHERE SALESID = @SALESID
AND DATAAREAID = @DATAAREAID;
UPDATE dbo.SALESLINE
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamics-ax: A Guide to Microsft Dynamics Cloud ERP - Dynamics AX Blog bot DAX Blogs 0 15.04.2011 00:12
Часовой пояс GMT +3, время: 22:32.
