Старый 19.10.2012, 21:12   #1
ax-erp: How to execute code at run time in axapta
Источник: http://microsoft-dynamics-ax-erp.blo...n-time-in.html
If you want to execute x++ code which you generate it at runtime then evalBuf method can help you.
This is an example.
evalBuf("info('This message is comming at run time code');");
You can use same with table,form ,report etc as per you requirement.
ax-erp: How to call external dll files from AX Blog bot DAX Blogs 0 10.10.2012 18:11
ax-erp: How to Enable/Disable fields in a dialog Blog bot DAX Blogs 0 19.09.2012 20:11
ax-erp: Create Forms by Using Code Blog bot DAX Blogs 0 17.09.2012 17:11
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes Blog bot DAX Blogs 0 25.01.2012 10:11
Часовой пояс GMT +3, время: 00:17.
