Старый 07.11.2012, 17:11   #1
Malaysia: Modifying multiple forms dynamically
Источник: http://axmas.blogspot.com/2012/11/mo...namically.html
1. In the AOT, open SysSetupFormRun class, and create a new method with the
following code:
private void addAboutButton()
FormActionPaneControl actionPane;
FormActionPaneTabControl actionPaneTab;
FormCommandButtonControl cmdAbout;
FormButtonGroupControl btngrp;
#define.taskAbout(259)
actionPane = this.design().controlNum(1);
if (!actionPane || !(actionPane is FormActionPaneControl) || actionPane.style() == ActionPaneStyle::Strip)
return;
actionPaneTab = actionPane.controlNum(1);
if (!actionPaneTab || !(actionPaneTab is FormActionPaneTabControl))
return;
btngrp = actionPaneTab.addControl(
FormControlType::ButtonGroup, 'ButtonGroup');
btngrp.caption("About");
cmdAbout = btngrp.addControl(
FormControlType::CommandButton, 'About');
cmdAbout.command(#taskAbout);
cmdAbout.imageLocation(SysImageLocation::EmbeddedResource);
cmdAbout.normalImage('412');
cmdAbout.big(NoYes::Yes);
cmdAbout.saveRecord(NoYes::No);
2. In the same class, override the run() method with the following code:
public void run()
this.addAboutButton();
super();
Microsoft Dynamics CRM Team Blog: Read-optimized forms Blog bot Dynamics CRM: Blogs 0 23.03.2012 04:25
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
furnemont: Interesting article: Microsoft CRM 2011 Multiple Forms basics Blog bot Dynamics CRM: Blogs 0 21.06.2011 19:11
axinthefield: Choosing a Single Deployment or Multiple Deployments of AX2009 Blog bot DAX Blogs 0 15.06.2011 03:25
Microsoft Dynamics CRM Team Blog: Thoughts on Forms Blog bot Dynamics CRM: Blogs 0 26.08.2008 00:11
Часовой пояс GMT +3, время: 23:26.
