Старый 30.11.2012, 16:11   #1
25,643 / 848 (80) +++++++
sashanazarov: Value cannot be null. Parameter name: x
Источник: http://sashanazarov.blogspot.com/201...er-name-x.html
Don't get confused, when trying to find where this error message was thrown: "Value cannot be null. Parameter name: x". Especially, when this is something thrown during AIF processing.
You might suggest that this is a label and you do find the label @SYS91439, but still you have no idea what is going on, e.g. no breakpoints with this label are hit.
So, it may well be something thrown by an arithmetic operation, which was passed a null value.
Another good reason to give meaningful names to variables and check for null values.
workflowax: Dynamics AX Workflow Error: Specified argument was out of the range of valid values Parameter name: constraintDate. Blog bot DAX Blogs 0 27.07.2010 01:10
Developer notes: Null value for ADO command parameter Blog bot DAX Blogs 0 03.05.2008 08:16
crmForm.IsDirty зохватит всех! Черничкин Станислав Dynamics CRM: Разработка 10 19.02.2008 08:10
C# and AX Development: Using the COM Business Connector in C#, the easy way (AX/Axapta) Blog bot DAX Blogs 0 15.12.2007 20:35
Часовой пояс GMT +3, время: 14:24.
