Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 21.03.2013, 13:35   #1
Kent is offline
Kent
Ax 2012 filter by Dimension table
Hi,
I created new table, which is used as financial dimension. So far it works ok.
It is possible to filter transactions by certain dimension code.
But the question is, how to filter by other fields from that dimension table? Not just by dimension code, but an example, by description of code.
Br, Maris
Старый 22.03.2013, 09:44   #2
S.Kuskov is offline
S.Kuskov
3,448 / 1792 (66) ++++++++
Press Ctrl+F3 and add linked DataSource. Or add linked DataSource previously when designing a form.
Старый 22.03.2013, 17:26   #3
AK-76 is offline
AK-76
Use DimensionAttributeLevelValueView + dimensionProvider class
http://sumitsaxfactor.wordpress.com/...anges-ax-2012/
За это сообщение автора поблагодарили: S.Kuskov (2).
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 02:51.
