Старый 22.03.2013, 16:11   #1
sashanazarov: Mandatory fields and table hierarchies
Источник: http://sashanazarov.blogspot.com/201...erarchies.html
If you have a table hierarchy, and there is a mandatory field in the child table, your data may become inconsistent in some cases.
For example, there are 2 tables (TestDog extends TestAnimal):
Let's make TestDog.OwnerName field mandatory and create a record in TestDog with blank OwnerName:
A warning is shown, which is correct. Now let's close the form. Normally, you would expect a dialog "Changes have been made in the form. Save changes? Yes/No". But in our case, the records are saved in both tables, with a blank mandatory field in TestDog.
dynamics-ax: Dynamics AX 2012 - Table & Type Hierarchies Blog bot DAX Blogs 0 27.01.2011 00:13
Dynamics AX Sustained Engineering: Fields modifiedDateTime and modifiedBy on Table InventSum Blog bot DAX Blogs 0 30.12.2010 00:12
dynamicsaxtraining: How to get original value for table fields during record modification Blog bot DAX Blogs 0 06.12.2010 23:11
axhelper: Add Fields to a table, using code_not the AOT In Dynamics Ax Blog bot DAX Blogs 0 04.10.2010 11:05
axaptafreak: Getting new table fields into your form datasource Blog bot DAX Blogs 2 24.01.2008 22:51
Часовой пояс GMT +3, время: 16:23.
