Старый 25.04.2013, 04:39   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Customer Free Text Invoice form the delete button is disabled.
Источник: http://blogs.msdn.com/b/axsupport/ar...-disabled.aspx
Issue:
The disable button on the Customer Free Text Invoice is disabled for a user which has the CustFreeInvoiceMaintain privilege assigned.
Summary:
This situation only occurs in Ax2012 as Ax2012R2 has made a change to the CustFreeInvoiceListPage entry point within the CustFreeInvoiceMaintain privilege of setting the Access Level to delete from read.
Workaround:
In Ax2012 open a developer workspace
- Open the AOT
- Navigate to Security - Privileges - CustFreeInvoiceMaintain
- Expand CustFreeInvoiceMaintain, select Entry Points - CustFreeInvoiceListPage
In the properties change the Access Level from Read to Delete
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
Часовой пояс GMT +3, время: 01:05.
