Старый 04.07.2013, 01:19   #1
emeadaxsupport: How to enable “Conditions” for Retail jobs in AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
TITLE:
DESCRIPTION:
We want to enable the possibility to schedule the Retail jobs (A-Jobs, N-Jobs or P-Jobs),
so they are running after each other. In this example it will be the A-jobs (A-1000 and A-1010)
  • First we need to add the code enabling the class to be selected in the batch setup
\Classes\RetailConnScheduleRunner\classDeclaration
/// Batch job to run the specified schedule
///MS START
[SysOperationJournaledParametersAttribute(true)]
///MS END
class RetailConnScheduleRunner extends
RunBaseBatch
RetailConnSchedule schedule;
boolean
forceRun;
BatchHeader
batchHeader;
RefRecId
onlyTargetLocation;
#define.CurrentVersion(2)
#localmacro.CurrentList
schedule,
forceRun,
onlyTargetLocation
#endmacro
  • Next you need to compile forward on the changed class
  • Third is that you need to generate Incremental CIL
  • The next step is now to create the batch jobs. The easiest is to go to the Retail Distribution schedule and then just
    “Create batch job” on the A-1000
  • After this step, we need to go to the System Administration / Inquiries / Batch jobs / Batch Jobs
  • Find the A-1000 and set it to Withhold status
  • Go to Batch Tasks
  • Add a new line and type A-1010 in the Task Description. (the exact naming is important here). Find the RetailConnScheduleRunner in the lookup.
  • Condition: After all tasks are created, go to the Condition area and add a new line and point to the job, you want
    to be have finished before this can start.
AUTHOR:
Kim Truelsen
PUBLISHED DATE:
3rd July 2013
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
emeadaxsupport: AX 2012 Retail: How to enable tracing in AX 2012 Retail Blog bot DAX Blogs 0 07.08.2012 15:11
Часовой пояс GMT +3, время: 03:30.
