#1 |
PowerShell Script to Run As A Different User
Источник: http://alexvoy.blogspot.com/2013/07/...different.html
============== Short script for PowerShell that allows you to start, for example, Dynamics AX client under a different user account. The main idea is to store the user's password as a secured string in a file, then to restore it from there and create credentials to launch the program. First, run the script to save the password: Write-Host "Input password for USERNAME..." read-host -assecurestring | convertfrom-securestring | out-file C:\Scripts\USERNAMEpwd.txt The following script can be saved in a file like RunDynamicsAXasUSERNAME.ps1 to be run as you need: #Alex Voytsekhovskiy 2013-07-29 # Based on the links: # http://blogs.technet.com/b/robcost/a...edentials.aspx # http://jdhitsolutions.com/blog/2012/...-pscredential/ ############################################################################################### # This script is to run Dynamics AX under a different user account # Without user input for credentials ############################################################################################### [String]$Username = 'DOMAIN\USERNAME' # Please check the following paths # Absolute path to Dynamics AX shortcut [string]$DynamicsAXAbsolutePath = 'S:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin\Ax32.exe' # Absolute path to the secured password file [string]$PasswordAbsolutePath = 'C:\Scripts\USERNAMEpwd.txt' # Get the secured password from the file $password = get-content $PasswordAbsolutePath | convertto-securestring # Create credentials for the program launch $credentials = new-object -typename System.Management.Automation.PSCredential -argumentlist $Username,$password # Launch the program echo "Trying to launch AX 2012..." start-Process -FilePath $DynamicsAXAbsolutePath -Credential $credentials I used the following links to create this script: http://blogs.technet.com/b/robcost/a...edentials.aspx http://jdhitsolutions.com/blog/2012/...-pscredential/ Источник: http://alexvoy.blogspot.com/2013/07/...different.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
