Старый 30.09.2013, 10:11   #1
kamalblogs: Dynamics Ax 2012 Reporting cookbook published & 5 reasons why you should go for it
Источник: http://kamalblogs.wordpress.com/2013...uld-go-for-it/
Hello everyone,
I’m very happy to inform you that the Dynamics AX reporting cookbook I authored is now published and available through major retailers online.
If you had pre-ordered it through packt then you should already have it in your hand. If not and you are still thinking if this book is for you, here are 5 reasons that tells you how buying this book is a good choice.
  1. Understand the inners of reporting Framework: This book helps you understand the framework portions like the controller, preprocessing, temptable marshaller to the depth with the help of flowcharts and diagrams. Just because you do it better when you know it better.
  2. Better choice of controllers and data source: The book has one or more examples for all the possible controls including the ones that are not found in the out of the box reports and discusses every possible data source available for the reports with examples. Just because you make a better choice when you know the options better.
  3. Speed up development and testing: Inside the book there are unique techniques that can help you speed up development as well gain time by quick tricks to fasten testing. Just because you get time to be creative when you make your routines easier.
  4. Implementation pattern reference: There are recipes in this book for typical development patterns like validations, defaulting values, building lookups, multive value lookups, inventory & financial dimensions and much more. Just because Google is not your only friend we are here too
  5. Analyze and Handle issues faster: The book has step by step in detail guidance to approach development issues, upgrades and design. It speaks about additional tools that can help you understand report performance and usage. Just because your mysterious must not remain unresolved.
curious and want to know more before buying ??
Look at the table of contents here  or Download the sample chapter from here
Interested in reviewing this book in  your blog ? Please contact me @casperkamal[at]gmail[dot]com
This blog has more SSRS tips revealed from the book read them here
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting - tips how to improve performance Blog bot DAX Blogs 0 18.09.2013 17:11
DAX: Financial Reporting – Even better with Microsoft Dynamics AX 2012, and now available in 36 languages Blog bot DAX Blogs 0 23.07.2013 03:17
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 05:28.
