Старый 25.10.2013, 02:12   #1
25,644 / 848 (80) +++++++
bojensen: Compile and CIL Generation errors when reporting extensions is not installed
Источник: http://blogs.bojensen.eu/?p=4751
Under certain circumstances, you may receive the followingcompile or CIL generation errors when installing Microsoft Dynamics AX 2012. SysStartupCmdGenerateSsasProject (object) has no validrunable code in method ‘buildProject’. BIGenerator (object) has no valid runable code in method‘classDeclaration’. BIAnalysisServicesProjectController (object) has no validrunable code in method ‘buildProject’. These methods are related to the Microsoft.Dynamics.AX.Framework.Analytics.DLL and is installed [...]
daxmusings: AX 2012's Hidden Compile Errors Blog bot DAX Blogs 0 07.02.2013 10:11
emeadaxsupport: Troubleshooting AOT Synchronization Errors Blog bot DAX Blogs 0 21.09.2012 05:24
palleagermark: Odd CIL compilation issue Blog bot DAX Blogs 0 20.12.2011 19:11
daxmusings: Resolving Compile Errors and Generating CIL is not Optional Blog bot DAX Blogs 0 13.12.2011 16:11
X++: .NET Interop to X++ When X++ Runs as CIL Blog bot DAX Blogs 0 21.09.2011 05:12
Часовой пояс GMT +3, время: 06:21.
