Старый 15.11.2013, 00:12   #1
25,644 / 848 (80) +++++++
Axilicious:Cleaning up after AxBuild.exe
Источник: http://www.ksaelen.be/wordpresses/dy...r-axbuild-exe/
So the AxBuild.exe tool has been around for a couple of weeks now and imho this is the best addition that a CU brought until now.
There have been some nice post about how it works and what you should keep in mind:
Though the tool is fantastic, we noticed that after performing a compile we always needed some manual actions to get the error count to 0.
Due to the limitations of AxBuild we always had approximately 100 errors left after compiling. A lot of them were custom .Net assemblies that could not be referenced at compile time.
So here is what you normally do when performing a full compile now:
  • AxBuild your environment
  • Import the HTML compiler output
  • In the compiler windows, select create project to create a project with all of the objects that were still invalid
  • Compile the project inside the Ax client
Well, just to make it easier, I have created a little tool which does the last 3 actions at once so that we do not need to perform these things manually. (And enabling us to incorporate it in automated builds).
The idea is to have a startup command which I can use like this :
ax32.exe -startupCmd=importandcompileaxbuildlog_
Due to the nature of the (imho not so good) design of the startup commands, it is not possible to enter a file path with spaces in your command prompt. Also putting quotes around it wouldn’t help too.
Therefor I have used the ‘*’ sign and the startup command will replace the ‘*’ charaters with spaces. For example:
ax32.exe -startupCmd=importandcompileaxbuildlog_C:\Program Files\Microsoft*Dynamics*AX\60\Server\AX60R2\Log\AxCompileAll.html
If you want to try it yourself, you can find an XPO containing the code here.
За это сообщение автора поблагодарили: Logger (1), b_nosoff (0).
axbuild.exe
X++: AxBuild.exe for Faster Full Compile of X++ Blog bot DAX Blogs 17 28.04.2014 22:17
dynamics-community.at: Erste Erfahrungen mit AxBuild.exe Blog bot DAX auf Deutsch 0 07.11.2013 13:11
Axilicious:AX2012 DLL Deployment and how AX binds DLL’s at runtime Blog bot DAX Blogs 0 22.05.2013 20:13
dynamicscpm: Preparing to migrate – a tip for cleaning up building blocks in Microsoft FRx Blog bot DAX Blogs 2 20.11.2011 14:35
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 15:45.
