Старый 24.11.2013, 21:11   #1
goshoom: Printing reports from code in AX2012
Источник: http://dev.goshoom.net/en/2013/11/pr...ode-in-ax2012/
How to print a report from X++ and change print settings in AX2012?
I have a concrete example for you – it should give a good idea how to do that even if your situation is a little bit different.
SrsReportRunController controller = new SrsReportRunController();SysUserLicenseCountRDPContract rdpContract = new SysUserLicenseCountRDPContract();SRSPrintDestinationSettings settings; // Define report and report design to usecontroller.parmReportName(ssrsReportStr(SysUserLicenseCountReport, Report));// Use execution mode appropriate to your situationcontroller.parmExecutionMode(SysOperationExecutionMode::ScheduledBatch);// Suppress report dialogcontroller.parmShowDialog(false); // Explicitly provide all required parametersrdpContract.parmReportStateDate(systemDateGet());controller.parmReportContract().parmRdpContract(rdpContract); // Change print settings as neededsettings = controller.parmReportContract().parmPrintSettings();settings.printMediumType(SRSPrintMediumType::File);settings.fileFormat(SRSReportFileFormat::Excel);settings.fileName(@'\\share\UserLicenseCount.xlsx'); // Execute the reportcontroller.startOperation();
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
goshoom: Code in forms Blog bot DAX Blogs 0 22.04.2013 11:11
ssmantha: Debugging .NET code called from X++ code in AX 2012 Blog bot DAX Blogs 1 11.11.2011 15:50
Часовой пояс GMT +3, время: 04:07.
