#1 |
Dynamics AX Sustained Engineering: Update conflict error thrown when an Intercompany Purchase Order is invoiced
Источник: http://blogs.technet.com/b/dynamicsa...-invoiced.aspx
============== ISSUE: When an Intercompany Purchase Order is invoiced, “Cannot edit a record in Purchase order lines (PurchLine). An update conflict occurred due to another user process deleting the record or changing one or more fields in the record.” error thrown. RECOMMENDATION: In \DataDictionary\Tables\CustInvoiceJour\Methods\interCompanyUpdate, reread method should be called first to make sure that PurchLine table buffer uses its latest versionId while select forupdate purchLine where purchLine.PurchId == interCompanyPurchId && !purchLine.IsDeleted { purchLine.reread(); if (inventTransIdMap.exists(purchLine.InventTransId)) { purchLine.PurchReceivedNow = inventTransIdMap.lookup(purchLine.InventTransId); } Similar function used in \Classes\SysCodeProfilerCleanUp\delete. Источник: http://blogs.technet.com/b/dynamicsa...-invoiced.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
