Старый 24.01.2014, 01:15   #1
Bug: One character in dialog field label causes wrong redrawing
Источник: http://alexvoy.blogspot.com/2014/01/...eld-label.html
Working on my previous project to change batch caption dialog field, I found a strange bug when it came to redrawing dialog window.
If we place any dialog field below a combobox with a label even of one character longer than the latter, AX fails to redraw the window entirely after modifying combobox value and changing Main instruction text.
protected Object dialog()
FormComboBoxControl combobox;
dlg = super();
dialogEventType = dlg.addFieldValue(EnumStr(uapInterfaceEventType), eventType, '1234567890' );
dialogAnother = dlg.addFieldValue(identifierStr(VendName), vendName, '12345678901');
// to add details to the caption and task description in batch tasks
dialogEventType.registerOverrideMethod(methodstr(FormStringControl, modified), methodstr(tmxRunBaseBatchSample, eventType_modified), this);
// to avoid user input in the field
combobox = dialogEventType.control();
combobox.comboType(1);
return dlg;
How to change Batch caption dialog field in run time. RunBaseBatch sample Blog bot DAX Blogs 0 17.01.2014 11:11
axtadka: Adding a field on dialog by addfield() method, when the type of EDT is known at run time, in Dynamics AX 2009 Blog bot DAX Blogs 0 17.11.2012 11:12
Microsoft Dynamics CRM Team Blog: Welcome to the World of Dialogs - Part 1 Blog bot Dynamics CRM: Blogs 0 02.02.2011 21:11
Часовой пояс GMT +3, время: 14:17.
