Старый 08.04.2004, 16:54   #1
paucer is offline
paucer
? Where is that field?
Could anyone explain one abnormal behavior:
LedgerJournalTrans table has field "company", but I can't see it when I use Add Ins>Table Browser. What happened?
I am sure that i didn't hide that field via left mouse button menu command "Hide".
Thanx.
Старый 08.04.2004, 17:02   #2
DMA is offline
DMA
This field is connected to Intercompany accounting.
Check if keys "General ledger advanced " and "Intercompany accountinig" are turned on in your configuration and you have license code for Finacial series II
Старый 08.04.2004, 17:19   #3
paucer is offline
paucer
ok, it seems you are right.
But does that mean that if there is no these licence coded it is impossible to insert record programmably?
LedgerJournalTrans LJT;
<assingning values to the LJT fields>
LJT.insert();
inside table insert() method the value is being assigned:
if (! this.offsetCompany)
this.offsetCompany = curExt();
but in further code the value of that field still remains empty that causes wrong behavior in the application
when AssetBook::lookupOpenBookIdForAsset() is invoked.
Старый 08.04.2004, 18:02   #4
DMA is offline
DMA
Изначально опубликовано paucer
LJT.insert();
Sorry but it seems you don't get a point of Configuration keys. If CF is assigned to a field and this CF is turned off means the field is excluded from synchronisation list, so it will be droped from SQL database. That's why the code above makes no changes.
axStart: Check if the table field is mapped. Blog bot DAX Blogs 0 07.03.2009 00:05
palleagermark: Set focus on a particular field on an EP page Blog bot DAX Blogs 0 27.11.2008 14:05
Разница NotInTTS и Found Logger DAX: База знаний и проекты 6 18.09.2008 12:35
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
Virtual field used in where clause bucken DAX: Программирование 4 09.11.2004 12:19
Часовой пояс GMT +3, время: 05:42.
