Старый 06.05.2014, 15:11   #1
palleagermark: Cross reference update never finishing on AX 2012 R2
Источник: http://www.agermark.com/2014/05/cros...finishing.html
I had a development box where I just couldn't get a cross reference update to finish. Even letting it run for days didn't help.
I finally got to run a SQL trace on what was going on. A thing that I probably should have tried a lot earlier. From the trace I could see that the cross reference for some reason was in an infinite loop on a particular form. I checked over a few hours and it never did seem to get past that form.
I killed the process and started a new cross reference agin, but this time I deleted the existing cross reference first:
When that was finished, I started a new cross reference update with the "Update all" option checked and this time cross reference was updated within the expected time frame.
emeadaxsupport: Country specific update to support SEPA export formats for remittance journal in Promissory Notes and Bill of Exchange in Microsoft Dynamics AX 2012 R2 is available Blog bot DAX Blogs 0 04.02.2014 22:11
Dynamics AX Sustained Engineering: Announcing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 15.12.2013 02:18
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
dynamics-community.at: Dynamics AX 2012 R2 Cumulative Update 6 released Blog bot DAX auf Deutsch 0 27.06.2013 13:11
emeadaxsupport: AX 2012 R2 In-Place Upgrade – Sometimes during the Data Upgrade Checklist the Detect Update Scripts step does not prepare any scripts to run. Blog bot DAX Blogs 0 19.04.2013 20:13
Часовой пояс GMT +3, время: 17:06.
