Старый 22.06.2014, 01:19   #1
emeadaxsupport: How to deactivate security policy in AX 2012 RTM for a query only due to tuning performance
Источник: http://blogs.msdn.com/b/axsupport/ar...rformance.aspx
Here is an example on how to increase performance by temporarily deactivating a query used to show open vendor invoices:
Open table Table VendTrans in AOT and expand methods and customize the method existsVendPaymReconciliationImport_SEBG() as follows:
/// This source code is freeware and is provided on an "as is" basis without warranties of any kind,
/// whether express or implied, including without limitation warranties that the code is free of defect,
/// fit for a particular purpose or non-infringing. The entire risk as to the quality and performance of
/// the code is with the end user.
/// Determines if the VendPaymReconciliationImport_SEBG is being used as a return format on an open vendor invoice.
/// True if the VendPaymReconciliationImport_SEBG is being used as a return format on an open vendor invoice.
public static boolean existsVendPaymReconciliationImport_SEBG()
VendTrans vendTrans;
VendTransOpen vendTransOpen;
VendPaymModeTable vendPaymModeTable;
boolean isFound;
//MSFT Support - 2 lines added to bypass GAB security
XDSServices xds = new XDSServices();
#DirParty
//MSFT Support - 1 line added below, bypass GAB security.
xds.setXDSContext(0, #InvalidContextString);
select firstonly RecId from vendTransOpen
exists join vendTrans
where vendTrans.RecId == vendTransOpen.RefRecId
exists join vendPaymModeTable
where vendPaymModeTable.PaymMode == vendTrans.PaymMode
&& vendPaymModeTable.ClassIdReturn == classNum(VendPaymReconciliationImport_SEBG);
// 1 line added below, revert back the security
xds.setXDSContext(0, '');
isFound = (vendTransOpen.RecId != 0);
return isFound;
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
emeadaxsupport: How to copy a budget to a new budget in AX 2012 using Excel Add-in Blog bot DAX Blogs 0 27.11.2012 15:11
emeadaxsupport: AX 2012 Retail: How to enable tracing in AX 2012 Retail Blog bot DAX Blogs 0 07.08.2012 15:11
emeadaxsupport: Dynamics AX 2012 Services: How to process big messages using File adapter Blog bot DAX Blogs 0 03.07.2012 00:12
Часовой пояс GMT +3, время: 03:27.
