Старый 22.06.2014, 01:19   #1
emeadaxsupport: Forms opening up with focus in background?
Источник: http://blogs.msdn.com/b/axsupport/ar...ackground.aspx
If you work with an installation where forms in MS Dynamics AX are opened in the background then the following code fix might help out here:
“Microsoft provides programming examples for illustration only, without warranty either expressed or implied, including, but not limited to, the implied warranties of merchantability or fitness for a particular purpose. This mail message assumes that you are familiar with the programming language that is being demonstrated and the tools that are used to create and debug procedures.”
Add a new static, client-side method to Classes\Application, as below:
client static void disableWindowGhosting()
DLL DLL;
DLLFunction DLLFunction;
container con = WinAPI::getVersion();
if (conpeek(con, 1) == 6) //Vista and Win7/Win2008R2 only
//this will disable window ghosting for this process only, for its lifespan only
DLL = new DLL('USER32');
DLLFunction = new DLLFunction(DLL,'DisableProcessWindowsGhosting');
DLLFunction.call();
Add a call to this from Application.startupPost(), like this:
if (hasGUI())
Application::DisableWindowGhosting();
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
emeadaxsupport: Forms not opening. Blog bot DAX Blogs 0 21.08.2013 10:11
emeadaxsupport: Changing the Background Color on AX Forms in AX 2012 Blog bot DAX Blogs 0 13.10.2012 00:11
axperf: Dynamics AX 2012: Forms on opening hide behind in the back Blog bot DAX Blogs 0 10.02.2012 05:16
emeadaxsupport: Forms with a high number of records take a significant time to show Blog bot DAX Blogs 4 12.09.2010 21:10
Часовой пояс GMT +3, время: 14:15.
