#1 |
emeadaxsupport: Microsoft Dynamics AX 2012 Mobile apps and Workflow approval via email.
Источник: http://blogs.msdn.com/b/axsupport/ar...via-email.aspx
============== Due to a recent change to the Azure Service Bus the following whitepapers are no longer accurate. The following white papers are impacted: http://www.microsoft.com/en-us/downl....aspx?id=36776 http://download.microsoft.com/downlo...ia%20email.pdf In the sections titled Creating a new Windows Azure Service Bus namespace is not longer valid. A update rolled on 8/24 did change the default behavior of newly created namespaces on the portal to support only SAS authentication. These steps work to create a proper service bus. 1) Install azure PowerShell http://azure.microsoft.com/en-us/doc...re-powershell/ 2) Connect the azure powershell to your subscription add-azureaccount 3) Run New-AzureSBNamespace -name SBName -location 'east us' changing your name and location. This will create the access control site properly. You should output similar to this. Name : SBName Region : East US DefaultKey : 2pRUX4K5EhE5XKvDsaS+816/Nrqzztkgur/CKsib40w= Status : Active CreatedAt : 8/26/2014 7:24:31 PM AcsManagementEndpoint : https://SBName-sb.accesscontrol.windows.net/ ServiceBusEndpoint : https://SBName.servicebus.windows.net/ ConnectionString : Endpoint=sb://SBName.servicebus.windows.net/;SharedSecretIssuer=owner;SharedSecretValue=2pRUX4K5EhE5XKvDsaS+816/Nrqzztkgur/CKsib40w= We are working to correct the official documentation. Thanks as always. Источник: http://blogs.msdn.com/b/axsupport/ar...via-email.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
