Старый 11.11.2014, 17:11   #1
DynamicsAxSCM: Post Misc. charges at time of Product receipt
Источник: http://blogs.msdn.com/b/dynamicsaxsc...t-receipt.aspx
Dear readers
The SCM-costing team in collaboration with SCM-Procurement team are happy to introduce a capability requested by customers for many years.
We introduce the capability of accounting for Misc. charges already at time of posting Product receipt.
This capability will provide customers with the opportunity to better estimate cost of purchase and avoid cost fluctuations at time of Invoice.
Configuration:
As this capability directly impact valuation of inventory assets and thus can be considered a change in accounting principle the feature will be controlled by a new parameter.
Path: Procurement and sourcing/Setup/Procurement and sourcing parameters
Note: In next major release of Microsoft Dynamics AX this capability will not have its own parameter but will be controlled by the Accrue liability on product receipt parameter on the Item model group.
We recommend the following parameter settings for accounting of inventories. Applying these recommended settings will make reconciliation to General ledger much simpler at end of fiscal period.
Module/Form
Parameter
Recommended setting
Inventory Management/Item model group
Post physical inventory
Yes
Post financial inventory
Yes
Accrue liability on product reciept
Yes
Accounts payable/Accounts payable parameters
Post product reciept in ledger
Yes
Procurement and sourcing/Procurement and sourcing parameters
Generate charges on product reciept
Yes
Accounts receivable/Accounts receivable parameters
Post packing slip in ledger
Yes
Production control/Production control parameters
Post picking list in ledger
Yes
Post reports as finished in ledger
Yes
Note: If you want to account for Misc. charges at time of posting product receipt and has checked marked “Generate charges on product receipt” you must as minimum also check mark “Post physical inventory” and “Post product reciept in ledger”
Defining Misc. charges:
Before the Misc. charge will be accounted at time of posting product reciept it has to fulfil certain requirements.
Misc. charge code:
The Misc. charge code has to be configured so it will be accounted as Inventory asset.
In Fast tab Posting under field group Debit the Type has to be Item. The Credit type can be either Ledger or Vendor.
Misc. charge calculation categories:
Not all Misc. charge calculation categories will post at time of Product reciept. The table below list the Misc. charge calculation categories applicable and how the value is calculated.
Misc. charge calculation category
Applicable charge value on product receipt line
Applied amount
Pcs
As per purchase order line applicable charge value
Received Quantity * Pcs value rate
Percent
Receipt net amount * % value
Proportional *
(Purchase order line applicable charge value / ordered quantity) * Received quantity
(Received quantity / Ordered quantity) * "PO line proportional Value"
*Proportional: A new Misc. charge calculation categories delivered as part of the feature
Note: Misc. charge calculation category = Fixed. No cost will be accounted for at time of posting Product reciept. The cost will still be accounted for at time of Invoice.
Note: Sales tax on Misc. charges will not be posted at time of product reciept.
Auto charges:
Auto charges will now be applied on time of Product receipt if records correspond to the rules defined above.
Example:
Prerequisite for the example:
Item: Misc. charge D1
Valuation method: Moving average
Auto charge: 10.00 Category = Percent
Misc. Charge: 200.00 Category = Proportional
Indirect cost: 1.00 % on purchased price + Misc. charge cost
1. A purchase order of 10 pcs. is created. The unit cost is agreed at 100.00
2. Adding Misc. charge manually
3. Allocate the Misc. charges
4. Confirm PO
5. Post Product reciept.
  • Because of insufficient stock at the supplier a
    partial delivery of 5 pcs will be received
  • Select “Receive now quantity” in field Quantity
Press button Charge: The user can validate the Misc. charges calculated by the system for the specific Product reciept prior posting.
Line net amount = 5 * 100.00 = 500.00
Charge code 04: 500.00 * 10% = 50.00
Charge code INS: 5/10 * 200.00 = 100.00
Press OK to post Product receipt
6. Validating posting of Product reciept
Purchase cost transactions
Validating the voucher
Account
Name
Calculation
Direction
Amount
600510
Indirect cost absorption
650 *1%
Credit
6.50
142100
Inventory
500.00 + 100.00 + 6.50
Debit
656.50
150690
Purchase accrual
5*100.00
Credit
500.00
600150
Auto Misc. charge absorption
500.00 * 10%
Credit
50.00
606200
(5/10) * 200.00
Credit
100.00
Validating the physical cost amount on Inventory transaction
7. Post a Product reciept of the remaining 5 pcs.
  • The postings are identical with the above
Account
Name
Calculation
Direction
Amount
600510
650 *1%
Credit
6.50
142100
Inventory
Debit
656.50
150690
Purchase accrual
5*100.00
Credit
500.00
600150
500.00 * 10%
Credit
50.00
606200
(5/10) * 200.00
Credit
100.00
8. Post Invoice of all 10 pcs and validate postings
  1. The system will automatically reverse the Misc. charges postings done at time of
    Product reciept.
  2. The system will automatically apply the same Misc. charges codes at time of Invoice
    1. New calculations will be performed as the base
      amount (Unit price) could have changed
    2. Additional Misc. charges code can be added
For simplicity in this example no change in unit price or additional Misc. charges are added
Voucher of Invoice
Account
Name
Direction
Amount
600510
Credit
0.00
142100
Inventory
Debit
0.00
150690
Purchase accrual
Debit
1000.00
600150
Credit
0.00
606200
Credit
0.00
211100
Vendor Balance
Credit
1000.00
Note: You will see a few 0.00 postings in the voucher. These are related to a current limitation in posting engine and will be addressed at a later time. The postings are not effecting any balances in General ledger.
Inventory transactions after invoice
Released versions:
The feature will be made available for following releases of Microsoft Dynamics AX.
  • Microsoft Dynamics AX 2012 R3
  • Microsoft Dynamics AX 2012 R2 (This will beavailable at later time)
DynamicsAxSCM: Understanding the product validation process in Dynamics AX 2012 Blog bot DAX Blogs 0 07.12.2012 03:12
DynamicsAxSCM: Troubleshooting the product release process Blog bot DAX Blogs 0 05.10.2012 17:11
DynamicsAxSCM: Using product templates in Dynamics AX 2012 Blog bot DAX Blogs 1 24.09.2012 11:05
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
Часовой пояс GMT +3, время: 06:22.
