Старый 10.12.2014, 13:11   #1
25,644 / 848 (80) +++++++
bojensen: Reset program cache file for all clients | Thomas Widmer’s AX Blog
Источник: http://blogs.bojensen.eu/2014/12/10/...dmers-ax-blog/
The following job resets the GUID which in turn forces all clients to create a new program cache file (AX_*.auc). A restart of the AOS is required.   static void forceNewAUC(Args _args){    #AiF    SysSQMSettings sysSQMSettings;    ;ttsbegin;update_recordset sysSQMSettings setting GlobalGUID = str2Guid(#EmptyGuidString);ttscommit;    info(“Restart the AOS Service to generate a new GlobalGUID.”);} (Source: http://blogs.msdn.com/emeadaxsupport...allations.aspx) Another option would…
Read more →
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
bojensen: SRS report does not reflect the new query changes – cache issue [AX 2012] Blog bot DAX Blogs 0 17.04.2013 03:25
bojensen: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] | Sreenath Reddy G – Dynamics AX Consultant’s Blog Blog bot DAX Blogs 0 15.03.2013 17:11
bojensen: Performing File IO with the TextIo Class [AX 2012] Blog bot DAX Blogs 0 02.01.2013 21:11
bojensen: How to add or delete a label file in Dynamics AX 2012 (Microsoft Dynamics AX blog by Zubair) Blog bot DAX Blogs 0 17.11.2012 11:12
Часовой пояс GMT +3, время: 19:59.
