Старый 13.01.2015, 15:54   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
KB 3023315"User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)" error when adding a record through Application Integration Framework (AIF) for a non-ad
Для тех кто активно использует AIF с AX 2012
KB 3023315 "User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)" error when adding a record through Application Integration Framework (AIF) for a non-admin user
PROBLEM
When adding a record through Application Integration Framework (AIF) for a non-admin user, you receive the following error message:
"User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)."
DESCRIPTION OF CHANGE
The changes in the hotfix include skipping the permission check if the database log operation is from kernel.
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: gl00mie (3).
aif, ax2012, hotfix, sysdatabaselog, журнал базы данных
emeadaxsupport: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId". The conflict occurred in database "YourDataBaseName_model", table "dbo.Model" Blog bot DAX Blogs 0 23.05.2014 13:11
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 16:12.
