Старый 08.03.2015, 17:15   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Voided sales order function
Источник: http://blogs.msdn.com/b/axsupport/ar...-function.aspx
Microsoft Dynamics AX has a function to control for the deleted sales orders or deleted lines, on this post will illustrate the voided sales order function, where the deleted sales order lines are stored in another form for reference only. First this function must be activated under accounts receivable parameter.
Accounts receivable| Setup| Accounts receivable parameters then under General go to Sales fast tab, under Setup field group, Tick the following option Mark the order as voided.
During the sales order transaction assume that the end user after select a sales line then delete it, the deleted line is moved to Voided sales order form
Let us create a new sales order line and delete it from the header
Then go to Sales and marketing| Inquiry| History| Voided sales orders
The voiced sales order form will open, and the voided sales orders will be shown as the following screen shot
The Voided filed has two options;
  • The first is Voided lines; which represents the sales order lines that have been deleted and the sales order header is not deleted
  • The second is Voided; which represents the sales order that have been deleted from the header
Go to Lines tab, which shows the voided lines.
You can press Show to show the sales order and order lines.
emeadaxsupport: Inconsistency between quantity in sales order and quantity in inventory transaction. Blog bot DAX Blogs 0 31.01.2015 17:11
emeadaxsupport: AX for Retail 2012-R3: Customer would like to pay for Sales Orders in Retail POS that were created in Dynamics AX Blog bot DAX Blogs 0 22.11.2014 01:19
emeadaxsupport: Sales agreement functionality when linking to Sales order lines Blog bot DAX Blogs 0 22.07.2014 20:13
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
Часовой пояс GMT +3, время: 06:24.
