Старый 09.11.2015, 13:11   #1
emeadaxsupport: How to update AX 2012 Enterprise Portal in a multi-server web farm
Источник: http://blogs.msdn.com/b/axsupport/ar...-web-farm.aspx
See this blog post for how to install AX 2012 Enterprise Portal in a multi-server web farm: http://blogs.msdn.com/b/axsupport/ar...-web-farm.aspx
If the web farm is load balanced and the load balancer was configured after EP was installed, then be sure the host files on each server in the farm has been updated with the local IP address mapped to the Host Header before you deploy changes to EP.
When you browse to the load balanced URL it will be resolved to the IP address of the load balancer which will route the request to a Web Frontend Server. If you try to deploy changes to EP without editing the hosts file, then the web application URL will be resolved to the load balancer instead of the local machine and the deployment will fail.
The hosts file is located under C:\windows\system32\drivers\etc
Add a line with local IP address mapped to host header on each server.
Example:
The web farm consists of 3 servers and load balanced URL is EP.contoso.com:
CA (SharePoint Central Admin) server with IP 10.10.50.101
WFE1 (Web Frontend) server with IP 10.10.50.102
WFE2 (Web Frontend) server with IP 10.10.50.103
On CA server add this line in hosts file:
10.10.50.101 EP.contoso.com
On WFE1 server add this line in hosts file:
10.10.50.102 EP.contoso.com
On WFE2 server add this line in hosts file:
10.10.50.103 EP.contoso.com
When updating Enterprise Portal, then we need to take into account changes to the following components:
- Web modules
- Webpage definitions
- Web controls
- Proxies
- Images
- Static files – (rarely updated)
In order to deploy changes to AX 2012 Enterprise Portal in a farm with more than one web server, then you can use one of the following options:
1. Deploy using AxUpdatePortal
On each web server run AxUpdatePortal jobs depending on what objects have been changed and needs an update. Ref. https://msdn.microsoft.com/en-us/library/dd261467.aspx
AxUpdatePortal –updatewebcomponent –treenodepath "Web\Web Files\Web Controls" –websiteurl http://EP.contoso.com - this will update all web controls
AxUpdatePortal –updatewebcomponent –treenodepath "Web\Web Files\Static Files" –websiteurl http://EP.contoso.com - this will update all static files
AxUpdatePortal –proxies –websiteurl http://EP.contoso.com
AxUpdatePortal –images –websiteurl http://EP.contoso.com
AxUpdatePortal –updateall cannot be used on the WFE, only on CA, as it will try to update the page definitions which can only be done on the CA server.
2. Deploy using Publish-AXWebComponent
On each web server use Publish-AXWebComponent command from either the Microsoft Dynamics AX Management Shell or the Windows PowerShell console. Ref. https://technet.microsoft.com/en-us/.../jj720274.aspx
On CA:
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" -AOTNodePathList "\Web\Web Modules" – this will deploy new modules and update page definitions
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" -AOTNodePathList "\Web\Web Files\Web controls"
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" -AOTNodePathList "\Web\Web Files\Static Files"
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" –Proxy
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" -Image
On WFE:
3. Deploy from AOT or Deployment form in AX
In hosts file on AOS change IP address to point to the web server you want to deploy to and then deploy from AOT or run deployment form in AX with update web application. To update the next web server then you need to change the IP to the next web server you want to deploy to.
E.g. you can have one line for each web server in the host file, one that resolves to CA and one to each WFE. Comment out the server you are not updating.
Example:
#10.10.50.102 EP.contoso.com
#10.10.50.103 EP.contoso.com
4. Deploy using AX Setup
Use AX setup on each server and uncheck configure for SharePoint and create site - this will deploy static files and dll's, similar to update web application in the deployment form (this will not deploy page definitions).
To update the CA server with page definitions use:
AxUpdatePortal –updatewebcomponent –treenodepath "\Web\Web Files\Page Definitions” –websiteurl http://EP.contoso.com
Or
Publish-AXWebComponent -WebSiteUrl "http://EP.contoso.com" -AOTNodePathList "\Web\Web Files\Page Definitions"
How to verify if the update was successful
  • Web modules:
    New module will be added to navigation menu (tab page).
  • Webpage definitions:
    In Enterprise Portal document library (EP > Site Actions > View All Site Content > Document Libraries > Enterprise Portal).
  • Web controls:
    In ep folder (C:\Program Files\Common Files\microsoft shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\ep) on each web server node.
  • Proxies:
    Proxy folder (C:\inetpub\wwwroot\wss\VirtualDirectories\80\App_Code\Proxies) on each web server node.
  • Images:
    In …\ep\images on each web server node.
  • Static files:
    In …\ep\scripts on each web server node.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
emeadaxsupport: Dynamics AX 2012: Some problems with setting up Form Authentication for Enterprise Portal Blog bot DAX Blogs 0 24.05.2012 14:11
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 15:19.
