Старый 15.11.2015, 15:13   #1
25,644 / 848 (80) +++++++
kurthatlevik: Synchronization problems in AX 2012 R3; Try disable track changes.
Источник: https://kurthatlevik.wordpress.com/2...track-changes/
If you are installing a ISV solution into a Contoso environment, and you suddenly see that you cannot synchronize, and you cannot see why:
Here is a tip that works for me;
Disable the track changes in the specified tables;
Then the synchronization is able to perform. After synchronization you can enable it again.
If you want to switch on/off in SQL, then this is the script for Switching off;
To switch them on again;
Happy Daxing !
kurthatlevik: Dynamics AX 2012 R3: Global recommended retail price Blog bot DAX Blogs 0 14.10.2014 11:11
kurthatlevik: AX 2012 R3 : Do not enable WMS-II and the new Warehouse and Transportation management in the same installation Blog bot DAX Blogs 0 15.05.2014 19:11
Часовой пояс GMT +3, время: 11:34.
