Старый 23.01.2016, 03:28   #1
Dynamics AX Sustained Engineering: Announcing support for SQL Server 2012 SP3 with AX 2012 R2 & R3
Источник: http://blogs.technet.com/b/dynamicsa...r2-amp-r3.aspx
Microsoft Dynamics AX 2012 R3 Cumulative Update 10 and AX 2012 R2 Cumulative Update 9 are now compatible with SQL Server 2012 SP3.
The Microsoft Dynamics AX 2012 System Requirements have been updated to reflect this change.
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF) Blog bot DAX Blogs 0 23.03.2015 22:12
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2012 and SQL Server 2012 SP1 with Dynamics AX 2009 SP1 Blog bot DAX Blogs 3 27.05.2013 14:41
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Часовой пояс GMT +3, время: 09:23.
